Difference In iPhone Battery Adhesive?
Is there any difference in the battery adhesive when it come to different iPhone models?
different sizes for plus models, iPhone 8 has stronger type and in 4 smaller strips
このアンサーは役に立ちましたか?
Yes I understand but I was thinking more if for example an iPhone 6 battery adhesive can be used for an iPhone 7 battery. I found a place where I could buy 10 adhesives for a low price so I was wondering if it would work. They seem to be the same I dont know. Appreciate your response.
yes you will be fine buying any.
If you are doing more than one battery replacement get a roll of red double sided tape you can get this from eBay, same price as one battery adhesive strjp for an iPhone 6 battery for example.
このアンサーは役に立ちましたか?
Yes I know. But I was wondering about the strips. They look the same for iPhone 6 and 7 for example. But thanks for the advice.
I would highly recommend buying the correct battery adhesive strips. If you just purchase any old double sided tape it will make it extremely difficult if you needed to replace the battery in the future. The strips designed for iPhones have ends that make it easy to remove.
このアンサーは役に立ちましたか?
I know. I prefer to use the strips than regular double sided tape. I just wanted too see if some adhesive are the same for some models. Appreciate the recommendation.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 507
