メインコンテンツにスキップ
モデル番号 A1418 / Late 2012 / 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7プロセッサ
212回答 すべてを表示
Not powering on after power supply replacement.
First of all it was not powering on with no LEDs lighting up on the logic board. I got a replacement power supply, fitted it and then I had the 1st LED on but it still did not power on.
I took out the logic board and took out the battery and re-seated the CPU and put it back together and it turned on and booted as soon as I plugged in the power (without hitting the power button). I restarted it several times and then eventually turned it off and tried hitting the power button but it seems like the power button is broken. I could not turn it off by holding the power button in while it was turned on.
Is there any way to short it on the board to see if it powers on and be certain the power button is definitely broken? I can’t seem to be able to find a replacement button anywhere online.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
The power button is not an Apple replaceable part ;-{ Its part of the rear case assembly.
You should be able to disconnect the cable and using a jumper short across the sockets solder connections to test the switch logic. Review Step 33 in this guide iMac Intel 21.5" EMC 2544 のロジックボードの交換
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
What is best to use to short the connections? If this doesn't work would would be the issue here? Considering it turns on after removing the cmos battery
さんによる
A simple piece of wire will do. Again your assumption was a bad power switch if the jumper fails to turn the system on then you have a power supply issue still.
The NVRAM battery only looses the settings within it.
さんによる
コメントを追加
回答を追加する
Daniel Gavillet さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 3
今までの合計 89
