How to do a Hard Drive replacement.
The hard drive doesn’t work anymore, What are the steps to replace it?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi @nickthekidnl ,
Here’s a link to the service manual for your laptop.
Scroll to p.40 to view the necessary pre-requisite steps and then the procedure to remove the HDD.
If you have an SSD installed scroll to p.42 to view the necessary pre-requisite steps and then the procedure to remove it.
If you wish to replace the drive(s) with the same make and model capacity drive etc, the part numbers are listed at the top of the the page (40 or 42).
If you search online, using the part number only in the search box of your browser, you’ll get results for suppliers of the part.
このアンサーは役に立ちましたか?
Looks like they have put the M2 drive on the bottom of the logic board. Here’s how to do it:
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 3
今までの合計 715
