Will not stop blinking
The machine will not stop blinking. Pressing it for 3 seconds or more does nothing. All it does is blink.
Are they quick blinks or regular blinks quick blinks are like 2 blinks per second.
If holding both buttons same time does not work then you should contact the customer service.
Does it produce espresso at all?
このアンサーは役に立ちましたか?
2 blinks per second and after some time it powers off.
Hi, can I jump on this thread with my problem,
Started with water coming out of the bottom of my nespresso inissia, tried a seascale to no avail,
Found a video on you tube to totally strip it down and clean it but after putting it back together both lights on top flash quickly and then when I leave go they stop flashing but nothing happens, have tried different resets etc, please help I need my coffee,,,,
このアンサーは役に立ちましたか?
bonjour
avez vous pu resoudre votre probleme?
avez vous penser que cela pouvait venir de la sonde de temperature?
過去 24時間: 1
過去 7 日: 7
過去 30 日: 20
今までの合計 14,892
It has only 2 been months that i bought this ? stop blinking I already waste 3 pods
Maricel Henaine さんによる 共有
