メインコンテンツにスキップ
2015年3月のアップデートではアップルの13インチMacBook Airは第5世代Intel Core i5またはi7プロセッサーを特徴としており、これによりわずかな性能とバッテリーライフの向上がされました。
623回答 すべてを表示
Replace a broken Display Unit / Interchangeable with other models?
Hi there,
it is very difficult to source a new display, mine is broken. Did anyone conduct an exchange of a Display of the MBA 13” Early 2015 successfully? If yes, which Display are compatible to exchange from older models/versions? As far as I have seen, only 2015 & 2017 are interchangeable.
Many thanks,
Marcus
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
You can buy the same from ifixit to make your Mac work again
さんによる
Hi Amily,
I am living in Germany, would be easier and cheaper for me to source it in Germany. Some EBAY listings offer screens from 2013 and 2014 models, claiming these would be compatible, but I doubt that. So I still would like to get an answer from someone who has exchanged successfully their Display for an 2013 or 2014 MBA Display to be sure I can buy one of those.
Thanks,
Marcus
さんによる
コメントを追加
1 件の回答
ベストアンサー
Not sure I follow you here the display assembly is the same across the Mac Air models from 2012 to 2017. Apple didn’t alter its design until 2018 with the new unit they released.
Here’s the needed part MacBook Air 13" (Mid 2013-2017) Display Assembly and here is the IFIXIT guide MacBook Air 13インチ Early 2015 ディスプレイアセンブリの交換
Here’s a more local source TheBookYard UK - MacBook Air 13" Complete Display (2013-2017)
MacBook Air 13" (Mid 2013-2017) Display Assemblyの画像
製品
$314.99
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Many thanks Dan,
I am aware that the design has not changed, but sometimes the cables are changed or had another (different) adapter. But if all the cables are 1:1 the same as in the older models, I am glad to hear this as I can source older Airs from 2013 for much less than 2015 models to get a working Display Unit.
Thank you again for your answer!
Regards,
Marcus
さんによる
Go to TheBookYard site and review the other options by its part number (661-7475) if you need a cheaper part.
The issue is the condition of the part not its physical age. I gave you the Grade-A part.
Here's the cheapest one you'll be able to find Grade C But I'll warn you it's not likely to be in the best of shape (scuffs and small dings)
さんによる
コメントを追加
回答を追加する
MacMarcus さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 81
