メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5sの修理情報とガイドです。モデル A1533、A1453、A1457、A1528、A1530、A1518。
3530回答 すべてを表示
Cant replace screen! help
I was replacing my current old lcd with my new one but when it came to putting the metal shield on i could unscrew two and the others would not unscrew how can i solve this? i tried everything i was making my self sick cause i felt like i was about to lose my phone
!! can i cut the two tabs off? please help!
Update!
i bent the tabs in just a little to fit the frame but is there anything else i can do instead of this everything worked but my screen wouldnt close all the way
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
Cutting those two tabs off is not a good idea. The screws used are PH000. If you could provide some photos of the part you are stuck on, that would be helpful for determining your issue.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
what will happen if i do? any screen damage? i used a phillip screw driver and no results its like its too tight
さんによる
Ensure you use a PH000 driver, as you can strip the screws if you are not careful. The frame will not seat properly, and you can cause damage to the display.
さんによる
コメントを追加
If you’re talking about the side-frame screws that hold the LCD shield in place the can be snapped off carefully. Is it ideal? No, but it can be done. Or you can purchase another backplate and be done with it.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
the screws on the side of the metal shield
さんによる
コメントを追加
Did you strip the screws that hold the shield in place? If so, I did one time, and just dremeled the heads off the screws not hurting the shield, then replacing the screws. You don’t want to cut those tabs, but only if you are going to replace the shield.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
no i didnt strip them
さんによる
make sure you have the right screw driver, and if you , try not to be afraid of giving it some more power. If it doesn't come loose, you may have to dremel the heads off the screws to remove the screws. Only issue is, you'll need replacement screws.
さんによる
コメントを追加
回答を追加する
ios user さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 10
今までの合計 92
