メインコンテンツにスキップ
2016年3月に発売された4インチのiPhone。ハードウェア仕様は6sに類似しています。シルバー、スペースグレイ、ゴールド、ローズゴールドのカラーが揃っています。16/64 GB容量、Model A1662とA1723
1049回答 すべてを表示
Apple logo jumping up and down.
Hello all,
I have a situation I haven’t seen before. A customer brought me an iPhone SE with a cracked screen. I put a replacement screen from iFixit on and when I turn it on, the Apple logo jumps up and down on the screen, the screen dims, gets statically, and just acts funky. I haven’t waited for it to boot all the way.
When I put the same (new) screen on a different iPhone SE, it works fine.
When I put the old cracked screen back on the SE I’m working on, it works fine.
Any thoughts?
Thanks,
Mitch
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
Did you try a second replacement screen?
さんによる
I haven't yet. I only have the one new screen from iFixit. It's just odd that the replacement screen works fine on one of two iPhone SE's. The replacement screen goes wacky ONLY on the phone I'm trying to put a new screen on. The cracked screen works fine when put back on the phone. No wackiness.
さんによる
コメントを追加
2件の回答
最も参考になった回答
The issue is usually* because the replacement aftermarket screen is not compatible on the SE model.
You'll need to source another replacement screen that is compatible for the SE.
For example you can use original 5S or SE screen on an SE.
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
It is a SE replacement screen from iFixit that works fine when put on another SE phone.
さんによる
Ok that is weird, the only thing I can think of is the logic board having a fault but that is ruled out as the old screen still works on it.
Might be a shot in the dark but is the phone up to date on the iOS software?
さんによる
Exactly! Weird. I've replaced hundreds of screens and have never encountered this. The software was up to date. I gave her the phone back because she had to leave the country today. I wanted to bring this to the forum because I have never seen or heard of this so I thought someone else may have. Thank you for the responses.
さんによる
コメントを追加
It sounds like it might possibly be damage to the phone’s logic board, possibly around the connection pins, you can try cleaning the connector pins with 99.5% isopropyl alcohol.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
When I put the cracked screen back on the phone it works fine.
さんによる
Hm okay, well you could try a hard reset when the device boots.
さんによる
コメントを追加
回答を追加する
Mitch さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 116
