メインコンテンツにスキップ
2015年9月25日にAppleから発売されたiPhone 6Sの修理情報とガイドです。モデル A1688、A1633。
2690回答 すべてを表示
iPhone 6s | Ribon Cable has been cut
While I was replacing the battery, the connecting black ribbon has been cut. I think it was for the front camera and the speaker. You can see from the photos.
Is that enough to replace the front camera/speaker?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
4件の回答
ベストアンサー
do you mean cable or ribbon, if you mean the cable that goes from the charge flex then no you will need to buy a new charge port, any of the ribbons are sold seperately
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
There may be someone selling this cable, however the upfront equipment and process cost needed to replace the cable alone will exceed the cost of the phone, therefore it is not economical to buy just one cable unless you are refurbishing screens commercially.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Remove the camera & speaker flex. It looks like it could be that one.
As the smaller one is for the home button, and the other one which isn't cut, I think is for the LCD.
If that part of the cable is from the camera flex, then you need a new front camera.
If it's not, then you'll need a new LCD.
You won't be changing the LCD flex without any proffesional refurbing kit.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Dear Duane,
I have added a new photo after removing the camera and speaker. It seems the ribon is for the camera.
Is the phone running without (unplugged) camera and speaker?
さんによる
コメントを追加
Dear Daniel,
Thanks for your reply.
I think it is ribbon, please find the below screen shot.
I found some parts on the spare parts categories. Is the below link is it for my problem?
iPhone 6s Test Cable for LCD Screen and Digitizer
iPhone 6s Test Cable for LCD Screen and Digitizerの画像
製品
$14.99
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
it could be an lcd ribbon in that case which means you may need a new screen otherwise it could be to do with the front camera/speaker or home button ribbon
さんによる
The front camera ribbon cable needs to be replaced. That is torn in the picture you've shown. Screen cables are OK
さんによる
コメントを追加
回答を追加する
nzmturkan さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 8
過去 30 日: 9
今までの合計 521
