メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2004-2008 Mazda RX-8の修理ガイド。2003年から2008年まで製造された日本製のスポーツカーです。
VIN DECODING for RX8
How do I decode my Chassis: SE3P 116798
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
ベストアンサー
Hi,
According to this web page, it says that Japanese cars made for the local market do not have VIN numbers but have chassis numbers instead, which do not contain as much information as VIN numbers. There may also be a model number associated with the chassis number which provides more specific model information.
Putting your vehicle’s chassis number into the Free Vehicle Search link on the web page, gives this result.
Here’s another link which may be of some help.
If you scroll down the page you will see entries for build year 2004 with Chassis ID of LA-3ESP which if you click on the specific model variants will give full details regarding the vehicle specifications.
Hopefully this is of some help.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
最も参考になった回答
Edwin Nordzievor  your VIN is incomplete. To decoded it you will require the full 17 digits.
The first 3 digits show the manufacturers ID code and the first character identifies the country of assembly. Next 5 digits identify attributes like body style, model engine etc. digit 9 of your Vin is used to validate the VIN Digit 10 is for the model year. Number 11 is for the plant where your vehicle was built and the last 6 digits identify a specific vehicle with the year, model or make. If you are uncomfortable to post your VIN on here, use something like this site
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
SE3P116798 is the only VIN on the RX8. It was purchased from Japan and my observation is that it is the only number on the car. Other searches online revealed that similar VINs were given to the RX8s in Japen. So how do I get the 17 digits for my car?
さんによる 共有
cars from Japan use their own chassis frame numbers as serial numbers, which don't convert to VIN's.
さんによる 共有
コメントを追加
回答を追加する
Edwin Nordzievor さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 36
今までの合計 2,997
