メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
以前のBlackBerryモデルから様々な改良が加えられた、初代BlackBerry Boldスマートフォン。
bb thrown on wall doesnt boot
threw bb to wall cant boot no light nothing.
-keeping it plugged and putting battery in, removing waiting30secs and repeating procedure leads nowhere.
-keep escape pressed for safemode boot doesnt work
-keep mute button pressed 30secs doesnt work
mystery selfhealings
-keep 10 hours offline and repeat above doesnt work
next appreaoch keep 24hours ofline and repeat above
-no recognition of usb in computer link
-wahts broken ?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Check your battery, make sure you have any kind of output. Make sure that your battery makes a connection with the proper contact of your phone. After that it is time to perform a teardown on your phone and see what is obvious broken/disconnected etc. But do start with the power to your device. Good Luck and let us know.
このアンサーは役に立ちましたか?
スコア 2
4 件のコメント:
nice idea but the usb doesnt recognise it. that does work usualy without battery, doesnt it>?
i suspect boot rom
さんによる 共有
THe battery is ok. If you ever have troubles wiht yours keep mute pressed 30-40 seconds
first plug in leave it plugged
pull batter wait 30 seconds
put in batter wait 10-20 seconds
keep mute top pressed for 30-40 seconds while on cahrger.
it should live again
turn device soft off while loading full
さんによる 共有
The reason why I always check the battery and contacts first is to make sure there is no shortcircuit to prevent the device from not being recognized when plugged in.
さんによる 共有
i see. The battery is ok. I exchanged batteries. So any idea waht could be broken > as i said the thing doesnt LED red, doesnt start no recognition as if the boot rom is damamged.
-is there a self healing possibility? leave it a day unplugged and it restarts? -read this a few times now
さんによる 共有
コメントを追加
回答を追加する
test さん、ありがとうございました!
統計データ:
過去 24時間: 5
過去 7 日: 8
過去 30 日: 22
今までの合計 1,364
