I need help on the printer
i dont know whats wrong with the printer its not letting the paper go though it so it gets jam in side
Hey Nelson,
Make sure there are no foreign objects that may be in the tray.
Make sure the paper is being loaded correctly
Check to see that the rollers are clear of debris
Open and close the access door to make sure it is fully closed
Make sure you aren’t over loading the tray
Hope this helps a bit
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 8
過去 30 日: 19
今までの合計 394
paper jam now cannot remove paper tray
John Bruncsak さんによる
