メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2012年6月発売 / Turbo Boost対応Core i7プロセッサ / 最大1 GB GDDR5ビデオメモリ
Replacement battery keeps not being recognized
I ordered and installed a replacement battery from iFixit and it seemed to be working fine for a while, however after running for a while the battery will not be recognized. When this happens, if I shut down and reset the SMC it will work again for a while but will later do the same thing resulting in needing another SMC reset.
I’ve also reset the PRAM along with updating to the latest SMC firmware for my Mac model all to no avail. I’ve inspected the battery connections many times and it appears to be plugged in just fine. I figured it’s not due to a faulty connection since a SMC reset kicks it back into gear, but this issue is really messing with my workflow.
Any help is greatly appreciated!
EDIT: I’ve also downloaded and ran CoconutBattery. After a fresh SMC reset, coconut says that the battery is in good condition and has no issues.
EDIT 2: Here is a screenshot of CoconutBattery with the SMC freshly reset (battery working)
画像
Here is after battery stops being recognized:
画像
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
1件のコメント
install this gem of an app CoconutBattery paste a snapshot of the main window for here so we can see whats happening iFixitでの質問に画像を追加する方法
さんによる
コメントを追加
5件の回答
最も参考になった回答
Did you contact them? I promise you they will replace it!
Contact iFixit Customer Support
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
For what it’s worth, I’m having the exact issue, and I’m on my second iFixit battery. The first one had this issue, so I tried unplugging and replugging in the battery connector and resetting SMC and PRAM all multiple times to no avail. I contacted customer service, and they were kind enough to send out another battery, but unfortunately, this one is having the same issue even with the troubleshooting described above. I can’t imagine a third will behave any differently. My Apple battery does not have the same issue, so I believe the problem has to be confined to these replacement batteries.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
They kindly sent me a new battery too.
But if you say true and none battery of this model works, I hope there will be a solution of refund.
さんによる
My second new battery works perfectly, thank you all and thank you iFixit!
さんによる
コメントを追加
Hey,
I have exactly the same problem as explained above.
Here are my screenshots of coconutBattery (before and after the battery is no longer recognized), do you think I should also contact the support?
画像
https://i.imgur.com/8ic3V00.png
画像
https://i.imgur.com/I2nscLd.png
Note: I have the same serial number as cknazze battery has ''too?!?
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Contact IFIXIT store for a replacement as your battery is defective. The packing slip will have the info on how.
さんによる
Great !
I'm going to do it, I just wanted to know if the second new cknazze battery worked well?
さんによる
コメントを追加
Hey there ill do have exect the same problem. Will contact the Support for replacement.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I’m having the same issue. Serial no is the same as cknazze. This is a coconut battery screenshot of when the MBP recognizes the battery. Can you see any obvious problems?
画像
I’ll post another screenshot from coconut when it stops recognizing the battery again.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Hi There,
Augie from iFixit here! Although I'm sorry to learn of the issue, we'll be more than happy to help.
Was this ordered from iFixit? If so, could you please email us at support@ifixit.com with your order number (or email address used to place the order)?
From there, we'd be more than happy to help get this handled in no time.
Thanks again,
Augie
さんによる
コメントを追加
回答を追加する
cknazze さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 19
今までの合計 903
