メインコンテンツにスキップ
2017年に発売されたAppleの第3世代スマートウォッチです。オプションで通信機能が付いています。
197回答 すべてを表示
Water damaged Apple Watch
I went out for a run, took my watch off because it died and I put it in my pants pocket. I washed those pants and now the screen is cracked and has water damage. It will not turn on. I’ve tried everything. Is there any possibility that my watch could be fixed and if so what would it cost? It’s a Series 3 I believe.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 5
3 件のコメント
My Apple Watch died while I was inside the Pool and now is full of water inside how would I fix this ?
さんによる
Hi my Apple Watch died too but I washed my hands my screen was already cracked and it stopped there got soap and water on the display and if I’m super unlucky it will be in the battery or logic board too I want to repair it by myself but idk what is broken or what to do someone I need advise and some thoughts if it’s riviveable
さんによる
Same thing happen to my Apple Watch. Did you have to replace everything or just a few different parts?
さんによる
コメントを追加
2件の回答
最も参考になった回答
If you believe it has water damage, you must disassemble and clean it using at least 91% isopropyl alcohol, (you can use this Apple Watch Series 3の分解 to do that) make sure to scrub everything with a toothbrush.
more details on water damage can be found here: Electronics Water Damage
It is a tough repair, but as long as you follow the instructions you should be fine.
このアンサーは役に立ちましたか?
スコア 9
1件のコメント:
I went to the beach and I didn’t lock my Apple Watch and now the brightness is red and I can barely see or know where things are, hoe can I fix it?
さんによる
コメントを追加
I was scuba diving and found a Apple Watch and I want to see if it can be fixed
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Breniecia Camphor さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 28
過去 30 日: 84
今までの合計 36,414
