メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
バッテリーのアップグレードやディスプレイの修理を含むPSP Goの完全修理マニュアルです。
Loss of audio Output From Units speakers.
Hi,
I have my psp go doing an odd thing.
It powers on fine and all functions are correct - save one. Audio.
Initially i susected that the device was assuming thati had headphones in - but when headphones are inserted the volume changes ion screen to the volume i had set last for headphones and audio is outputted through the headphones.
I then suspected that there may be dirt in the dock and thourghly cleaned the dock. Still no sound from speakers.
I then stripped PSP down as per your guides and looked at the speakers themselves - visually nothing "seems" wrong.
What areas should i be focussing on to rectify this fault?
Is it possible the speakers have blown after a heavy bout of dance/trance bass?
If so where can i obtain replacement parts?
Thanks in advance
Coxy
-EDIT-
Reading other psp go problems i found this fuse diagram.
http://www.mr-vizitkin.ru/images/stories...
I dont speak/read russian and dont know if these fuses are relevant.
Anyone care to share a translation?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
5件の回答
ベストアンサー
SOLVED
It is a piddly little fuse on the right side of the motherboard as you remove rear case.
It is marked with the letter L.
My fix is more of a bodge tbh.
I desoldered the fuse and used a bit of thin wire to make the circuit.
to make the fix permanent i need a new fuse lol.
Anyways hope this helps someone out in the future
このアンサーは役に立ちましたか?
スコア 4
6 件のコメント:
Great job, now all you have left to do is to accept your own answer. That way we will know that this works. Again, great job.
さんによる
Fuses blow to protect the rest of the system. By bypassing it you risk serious damage
さんによる
Here's what mine looks like (I desoldered those three little fuses):
https://i.imgur.com/SF8DQyg.jpg
When I get some thin wire soldered over the contacts to make the circuit, the PSP stops booting up. I take it off and it goes back to working (yet with no sound).
This is literally my first time using a solvering iron, so I'm wondering: is it possible that my board has gotten so messed up to the point that I'll no longer be able remake the circuit? Or am I just not soldering the contacts together correctly, and therefore should keep trying?
さんによる
I worked for me, thank you so much
さんによる
Worked for me as well..at first i put a F2 fuse that you usually put in the nintendo DS because i have many extra of those fuse but the sound quality is not great and kind of low, it also has static, so i just the bridge it and the sound quality is perfect..i dont know what fuse the psp go use or where to get it. If i happen to get my hand on one may i will put that fuse.
さんによる
1以上のコメントを表示
コメントを追加
I had the similar problem and by repairing the fuse problem solved.
Thanks Coxy.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
How exactly did you repair the fuse?
さんによる
コメントを追加
Im having the same problem here. No sounds through speakers. Earphones works perfectly.
I didnt silde the fuse of but I tried to connect 2 sides of a fuse with a wire but when they were connected the psp didn't boot up. when I remove the wire everything works again but still no sounds
is there anyway I can check if its really a fuse problem or not ? I'm just a noob so please help xD
I know this is an old topic but please help me !
Thank in advance :)
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Same thing is happening to me :\
さんによる
コメントを追加
i replaced the fuse. now my start/select button don't work. You think related ?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
What did you replace the fuse with?
さんによる
コメントを追加
^ you might have not have done it correctly.
Make sure you didn't leave any residue around the components. It can cause faulty things to happen.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Coxy さん、ありがとうございました!
統計データ:
過去 24時間: 6
過去 7 日: 23
過去 30 日: 107
今までの合計 17,861
