メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2015年9月発売のJBL Xtremeは、防滴仕様のポータブルBluetoothスピーカーです。
initial charging problem and etc
I hope someone could help me, I just bought my JBL extreme 2 days ago, I did charge it for the first time. It started to charge but when it reaches 4th LED it did not charge. Then from the 1st LED it jumps to 4th LED. What may seem to be the problem of my JBL?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
5 件のコメント
now it wont fully charge. if its plugged in to the power outlet it says fully charged, same thing happened in my phones meeter(in the JBL connect). I then unplugged it and it indicates 80% power. its a defective device i guess. but i lost my receipt
さんによる 共有
Same thing happened to me, the battery on the speaker is defective. You have to contact JBL and have them replace it or you can do it yourself if that's not an option.
さんによる 共有
How do you change the battery yourself?
さんによる 共有
My speaker is turning on but not charging.. I plug the charger in and it's not charging at all.
さんによる 共有
I have changed my JBL battery and is not charging but the charging port is ok, what could be the problem
さんによる 共有
コメントを追加
2件の回答
ベストアンサー
There are many possibilities.
Leds aren’t always accurate on electronics. But yes,that sounds extreme. It could be as simple as a bad battery. It could be a bad charger as well. I’d not those 2 things,it’s the circuitry. It could be a component issue.
If the battery life is fine,but just an inaccurate indication of battery,it could also be a faulty battery meter.
Sometimes charging until it won’t charge(keep it plugged in for a while after it hits 4th led or appears to stop charging),then drain it until it shuts off,then repeat the full charge step. In many devices,this calibrates the software meter for the battery,to make it more accurate.
have you tried using it for a while at a time? Is the battery life ok,setting aside the meter?
worse case,you could return it as defective,right? Just swap it out?
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
yes, i have used it yesterday with an estimated 80% battery it lasted for 6 hrs with full volume. charged it for 30mins at night then played music for like 6hrs with below 20% volume and after i wake up its dead. as i wake up, plugged it in and took a shower, by the time i finished shower, the battery went 80% on my phones meeter, JBL connect app to be specific.
さんによる 共有
コメントを追加
My speaker is turning on but not charging. I plug the charger in and it's not charging at all.
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
My JBL speaker is turning on but not charging. I plug the charger in and it's not charging at all. How can I fix it?
さんによる 共有
Replace battery. Look up guides online to replace the battery. Takes about 30 min.
さんによる 共有
I have new battery I replace it and its good but if I charge it stop on 4 level still blinking make ages to make it fulll what should i do? Do I need to drain in to calibrate.
さんによる 共有
コメントを追加
回答を追加する
jed roman malata さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 41
今までの合計 14,019
