メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2015年9月に発売された、ZTE製の5.5インチスマートフォン。
How to fix storage space running?
keeps says storage space is running. How can I fix this problem?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
Hi @islands7
If you have a ZTE ZMAX 2 check if it has Android Ver.6.0 installed.
If not update the firmware to this version and then you can try to format the SD card as internal storage.
If you need more storage change the SD card to a max of 64GB to give a total of 80GB which is no more that what was possible before but now you can have apps on the SD card as well.
I did say try, because a lot depends on what options the device manufacturer will allow with the firmware that they use in the phone.
Also I'm not totally sure with your model that if the above works that when formatting the original SD card it might erase everything from the card so maybe do a backup first or use a new SD card
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Dear Thompson,
Now a days many of user experiencing the same issue.
it can be solved easily by
  1. Adding one memory card. the move some internal memory file (Phone stored personal data) to external memory.
  2. Uninstalling unwanted application
  3. Resetting your phone (Your data will lost).
Best of Luck
For any further queries you can comment here
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Did not work, no advice about moving apps to SD card when no option displayed
さんによる 共有
コメントを追加
回答を追加する
r.s.thompson さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 15
今までの合計 457
