メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
HP製のレーザープリンター。12Aトナーカートリッジを使用し、5%の印字率で2,000枚の印刷が可能。印刷速度は毎分15枚(PPM)。
Paper feed processing problem
My HP Laser Jet 1012 printer successfully prints a page, but will not feed through the printer entirely and a second page becomes jammed in the feed mechanism
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
1件のコメント
I was having the same problem and the iFixit diagnosis, i.e., that there was a problem with the pickup roller was correct! Here is a guide to cleaning or replacing your pickup roller from the HP web site: https://support.hp.com/us-en/document/c0.... My problem was solved just by removing and cleaning it.
さんによる 共有
コメントを追加
2件の回答
ベストアンサー
I believe there are maintenance kits for these models which are usually expensive, but more times than not it’s the pickup roller. Try another toner as well. I have seen in certain printer models where the toner can cause jams.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
The User Manual (which you can get online) recommends:
  • Cleaning the pickup roller with a lint-free cloth and rubbing alcohol. Just tried that and it enabled my printer to grab 3 pages one after the other (instead of jamming after just one).
  • Alternatively, replacing the pickup roller. I see you can order some on Ali Express. Haven't tried that yet.
In the meantime, a temporary solution is to stand by the printer while it prints and manually load one page at a time.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I replaced pickup roller $25 and still have same problem. Now thinking it's sensors, in which case, probably bye-bye printer. Otherwise, this printer has been the best tech investment ever in terms of stability, function and reliability, so missing in other gear.
さんによる 共有
コメントを追加
回答を追加する
Ellen さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 50
今までの合計 2,761
