メインコンテンツにスキップ
2010年4月発売。2.4, 2.53 GHz Core i5 or 2.66, 2.8 GHz Core i7プロセッサ
590回答 すべてを表示
Why is my trackpad not working properly?
The trackpad on my Macbook suddenly stopped responding properly, when I move my finger the cursor stops intermittently. I found two workarounds that might give some clues:
1) if I apply even just light pressure under the trackpad the cursor moves as it should,
2) it also works if I unplug the power source, ie. in battery mode! (not ideal, since my battery is seriously bad)
Any ideas what might cause this problem?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
Thanks guys! As it happens, the trackpad started working again before I could try any of your suggestions. If I had any less experience with computers I would say this is very strange…
Now I have the problem of USB-Midi not working with the power source attached, but that’s off topic…
さんによる
@mholmqv - I would still look at your battery as this sounds like a classic case of a swollen battery.
さんによる
コメントを追加
2件の回答
最も参考になった回答
It sounds like you have a double whammy here. If your Battery is going it could be pressing on the trackpad from below, often times the battery swells up. I would test it using CoconutBattery Post a snapshot of the main window here so we can see how it looks iFixitでの質問に画像を追加する方法. If needed replace it and you still may need to replace the trackpad and its cable if they got damaged. MacBook Pro 15" Unibody Early 2011 のトラックパッドの交換 which is the same process for your system. And here’s the battery info MacBook Pro 15" Unibody Mid 2010のバッテリーの交換
MacBook Pro 15" Unibody Mid 2010 バッテリーの画像
ガイド
難易度:
簡単
10 - 45 minutes
MacBook Pro 15" Unibody Early 2011 トラックパッドの画像
ガイド
難易度:
中レベル
45 minutes - 2 hours
iFixitの画像
ガイド
難易度:
とても簡単
2 - 5 minutes
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
try SMC and PRAM resets. those solve most software related Mac problems. if SMC and PRAM resets don’t work then you might have to replace the trackpad.
MacBook Pro 15" Unibody (Mid 2009-Mid 2012) Trackpadの画像
製品
$59.99
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
mats.holmqvist さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 3
今までの合計 1,790
