はじめに
MacBook Pro 15" のマジックタッチが効きませんか?新しいトラックパッドで取り戻しましょう。
スパッジャーの平面側先端を使って、トラックパッドケーブルを覆っている大きな黒色テープの端をつまみます。
テープを剥がし、トラックパッドの邪魔にない位置に折り曲げます。上部ケースの中に残したままにすると、再組み立ての際に便利です。
デバイスを再組み立てする際は、これらのインストラクションを逆の順番に従って作業を進めてください。
69 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
翻訳を始める ›
25 件のコメント
Used this guide for a mid-2010 chassis, which seems the same. I'd recommend moving steps 23-25 to happen between steps 3 and 4. Basically, take the battery out first, immediately after removing the bottom cover. Also, replace it as a last step in reassembly prior to placing the bottom cover back on. What I found was that placing the logic board back into the machine (reversing step 22) was difficult with the fairly stiff battery connector cable. If you have better mojo than I do with a spudger, good on ya mate.
Definitely follow the advice about battery out first and the tip regarding double sided tape and corrugated board is really good. Easy to follow steps and worked perfectly.
Is it necessary to follow all the steps? My battery blew up; shattered the trackpad. Took battery out. Laptop works perfectly but need to replace trackpad. So since the battery is out, do I need to take everything else out, too? I do better with videos than still pictures. Dyslexia rules.
I have followed the steps, now my keyboard and trackpad is not recognised by mac os............ i have checked the cables, everything is connected......
I'm fed up.
mbouchet42 - 返信
