メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Bose 3-2-1 Home Entertainment Systemは、Boseの2.1chホームシアターラインにおけるDVDベースのホームメディアシステムシリーズです。Bose 3-2-1 Home Entertainment Systemは2001年から2006年の間に販売され、ブラックとグラファイトのカラー展開がありました。
Bose AV 321 Subwoofer Not Working.
Bose Service centre says the parts are not available in India hence can’t repair. Buyers of bose are passionate about sound, difficult to just give up.
The Bass Module stopped working after a short circuit but the speakers are working.
Who would be able to fix this?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
5 件のコメント
Hi Puneet Rawat
What had you tried?
What issues you are having now?
like able to turn on but no sound?
さんによる
Mine is well soldered but still no sound to the sub woofer except the smaller speakers only. What could be the problem? i have changed the TDA7396 twice now but no joy
さんによる
Hi Puneet,
did you manage to fix this? I’ve got exactly the same problem. I tested all resistors and capacitors up / from TDA7396 and they seem to be fine. I also replaced the TDA7396 as you did with no sucess. I’m really lost.
Felipe
さんによる
scusate il problema e di un chip siglato A3089G
sapete dove posso trovarlo?
さんによる
checco70t: How do you arrive to the conclussion that the problem is with that chip? Also, where is this chip located? it's not displayed in the electrical part list in the service manual
さんによる
コメントを追加
3件の回答
最も参考になった回答
Puneet Rawat  this could be a Bass module issue on your Bose. Post some good pictures of the modules etc. with your question. That way we can see what you see. Use this guide iFixitでの質問に画像を追加する方法 for that.
Here is the schematic for the module and you can start checking components with a multimeter. Let us know what you find.
画像
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
Have you checked the fuse?
From Bose Troubleshooting guide:
”AC mains power is connected by the line cord via jack J1. A slow acting fuse F1 is connected between J1 [D7] and the locking primary connector J3 (or J2 or J4) to protect against faults. A Metal Oxide Varistor (MOV) VR1 is placed after the fuse and across the line. It is used to protect against lightning strikes and other line transients. “
I did some research and it sounds like bad solder joints are common in this unit, So I would look for any cracked joints, cold solder, etc. while you are in there inspecting the fuse.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Mov VR1 do you know wich one can i buy
さんによる
First you should use a meter to confirm that the part(s) is(are) bad. Start by re-flowing the solder to those parts. You can also short the fuse to see if it works, but I wouldn't recommend leaving it that way.. the fuse is there for safety of you and the device.
I found that part on tessco
https://www.tessco.com/product/suppresso...
さんによる
コメントを追加
ciao ragazzi io ho il problema uguale non va il sub il difetto e il chip A3089G sulla scheda madre del av3-2-1 potete darmi lo schema oppure sapete che sigla a questo chip? e dove poso reperirlo?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Puneet Rawat さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 18
今までの合計 4,587
