メインコンテンツにスキップ
2015年11月11日にAppleより発売されたハイパフォーマンスタブレットコンピューターです。
131回答 すべてを表示
Touch Filter Replacement help
Hey Guys, I have recently done the screen replacement on the iPad Pro 12.9 1st gen and afterwards have lost all touch. I can’t seem to find any schematics or anything online. But was wondering if anyone could help me with what filter I can use to replace the existing one.
Any help would be appreciated
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
5件の回答
ベストアンサー
Take a look at this answer Anyone got back light schematics? by our good friend @oldturkey03, this should help.
このアンサーは役に立ちましたか?
スコア 4
2 件のコメント:
Yea it’s the filter next to the 2nf cap. I’m just wondering I have a 6s board spare. Would there be the same filter on there ? Is it just a generic filter.
さんによる
There's no such thing as a generic filter...these are ferrite beads and there are thousands of different specs. You could use the same one as the iPad Air 2, which is a 120R/450mA/0201 and see if it handles the current load properly by leaving the display at maximum brightness for a few hours.
さんによる
コメントを追加
You'll need to fill in the blanks here. You take about a filter what do you mean?
From what you are describing it sounds like your digitizer is disconnected or the ribbon cable is damaged. Review this guide iPad Pro 12.9インチ スクリーンの交換. It’s also possible you have a bad one as well.
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
Hey Dan. Sorry that was very vague. So after checking the logic board. There was a burnt out filter. Just above the screen flex connector on the board.
I’m just wanting to no if there’s a substitute filter I can use from another board ?
さんによる
@petespcrepairs Take a good clear pic of the area so we can see.
さんによる
Hey dan. IF you have a look at the link Minho just posted. You can see the filter that I’m referring too. It’s right next to the 2.0nf cap above the lcd connector.
さんによる
@petespcrepairs - Sorry guy I don't know its value
さんによる
コメントを追加
Touch Filter MURATA BLM03AX121SN1D 120 Ohm Ferrite Bead 0402 (size)
video Filter MURATA BLM15EG121SN1D 120 Ohm 1,5A Ferrite Bead 0402 (size)
you need hot air for microsoldering ;o)
I still have enough lying around here and would send them out if necessary
Update (10.02.2021)
Mouser-Nr.: 81-GRM0335C1E2R0CA1D
specs and ordering here
https://www.mouser.de/ProductDetail/81-G...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
What about the 2nf cap. Anyone know specs or where to get them?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
experience has shown that it works without the capacitor even without a jumper
check the named filters and swap them if necessary, that's all.
さんによる
コメントを追加
What do you mean by “check the named filters”
Is there a doc or specs somewhere here on this forum?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Peter さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 12
過去 30 日: 35
今までの合計 2,317
