メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Fujifilmのこのインスタントカメラは、以前のモデルよりもさらに薄く軽量なボディを誇ります。Mini 8は、推奨絞りを撮影者に知らせることで撮影をサポートします。また、ソフトなポートレート撮影で魅力的な仕上がりにするハイキーモードも備えています。
Film is stuck half way through the film slot
I put in a new film cartridge… and you know the first black cover that’s supposed to come out before taking any pictures? IT GOT STUCK
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
1件のコメント
I have experienced the same problem. At the end it turned out to be a battery issue; so indeed change the batteries while the device is still "on".
I did open the camera (remove all screws) to pull out the cardridge and the black cover; but it was not so easy (at end the end useless, since all lights stayed blinking). The blinking only stopped after a new (third) set of batteries.
さんによる
コメントを追加
4件の回答
最も参考になった回答
Hi Amsi,
Firstly don’t take out the cartridge or try to, this could expose the film, which isn’t what you want to do, otherwise it will kinda like activate the film. But that might be the only way out, and you most likely have tried to do that.
The Film roller may have malfunctioned, there is a mechanical roller in the camera which is used to eject film from the camera. You could always try to slowly pull the black film cover from the slot. I am not entirely sure on how to help you, but if it is new, then get a refund. I’m am not sure what condition your camera is in (battery wise) but you may need a new battery?
Fujifilm Instax Mini 8 Troubleshooting
If you do want to just open the camera and pull the cartridge out, do it in a very dark place so that the film won’t get exposure and so that it can be usable.
Hope this was use-full, and I wish you luck!!
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Hey, the same thing happened to me! DO NOT try taking it out; for me, all I had to do was change the batteries. As soon as they were changed out, the rest of that little black film rolled out.
さんによる
コメントを追加
my flim is stuck half way and hwen i try to take the back flim pack out its not working
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
hey just wanna let you know. no need to be panic. in some cases the battery pack is not completely new and might be "low" on power. what i would suggest is just turn it off then back on. the motor should be continue the process of printing
さんによる
コメントを追加
Hey I had this same issue this was a real struggle for me first I changed the battery’s and that could be your issue but if that does not work I took the screws out of the sides of my camera and took out the film that way you have to be really careful but it should get the job done
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
This is currently happening to me and the blinking won't stop
さんによる
コメントを追加
回答を追加する
Amsi Duarte さん、ありがとうございました!
統計データ:
過去 24時間: 9
過去 7 日: 23
過去 30 日: 123
今までの合計 33,305
