メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
HP OfficeJet 4630はワイヤレス接続のカラーインクジェット、オールインワンプリンターです。
Ink cartridge failure help
I have a HP 4630 OfficeJet Printer. I have a new HP 61 black ink cartridge that I ordered from HP. I put it in the printer, and it continually says, " Ink Cartridge Failure". I have done all I know to do, reset the printer, cleaned the contacts, etc. I have been on HP.com and nothing works. It is out warranty, so you can only access information on HP.com for tech help. Does anyone know anything to help me with this problem?
Here is other messages that shows on the printer
1. Ink Cartridge(s) Problem The following Ink Cartridges must be replaced. I have brand new ink cartridges.
2. It was printing about 2 weeks ago, when I replaced the empty ink cartridge. Then, it stopped. I called HP and they sent another one. Now, it will not accept the new cartridge.
3. I have downloaded print drivers from HP.com and I have uninstalled and reinstalled the printer software about 4x.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
2 件のコメント
Mine prints but nothing is printed out on my paper? THe ink cartridge indicator shows over 1/2 full?
さんによる
Mine won't accept genuine HP cartridges. Says incompatible cartridge (new black). HP Support says to clean everything. Did that but same display. HP says to take it in for repairs.
さんによる
コメントを追加
5件の回答
ベストアンサー
Whew! I have been at this printer off and on and had tried everything. Lo and behold, today I just took some scotch tape and taped over the bottom of the ink cartridge (The part where the original tape comes when you buy a new one and take it off) and inserted it back into the printer, then I took the tape off and inserted the cartridge back in the printer. All of a sudden the error message "ink cartridge failure" was gone and the control panel on the printer showed and was up ready to print. I can't even explain it. But, it is printing again. Thanks everyone!
このアンサーは役に立ちましたか?
スコア 5
5 件のコメント:
van you explain this as i am currently having the same problem
さんによる
I’m having the same problem
さんによる
Didn't fix mine.
さんによる
Mine neither. I hate printers
さんによる
It worked for me as well 8 years later. I don't even believe it and have no idea why, but if you have the same problem, give it a try!
さんによる
コメントを追加
最も参考になった回答
Turn off the HP printer and unplug it1.888.274.2102 open the cartridge access door and carefully remove the ink cartridge. Check for dried ink or debris on the copper contacts and gently clean them with a lint-free cloth slightly dampened with distilled water. Let it dry completely before reinstalling. Ensure the cartridge is properly seated. Restart the printer and run a cleaning cycle from settings. If problems persist, replace the cartridge with a compatible new one.
このアンサーは役に立ちましたか?
スコア 6
コメントを追加
can you explain more detailed how you fixed it
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I read the comments above, put a tape over the black ink ink part, took it off and put it back, and it didn't work, I then took out my color ink, which the ink part on the color ink had melted, i seldom used the color ink, it was saying I am now on single ink, and it worked! now it's printing!
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Surprisingly, removing the color ink cartridge, closing the empty location of the printer's color ink "clip" as much as possible, gave me the "printing from single cartridge" comment, it then printed a (blank) alignment page, I scanned it, read "alignment failed" and chose "OK", another attempt, alignment of just black page printed and scanned, and then itprinted fine with just the black ink.
さんによる
コメントを追加
Since you've already tried multiple new HP 61 cartridges, cleaned the contacts, reinstalled the software, and reset the printer, the issue may not be the cartridge itself. It's possible that the cartridge carriage contacts inside the printer are dirty, damaged, or no longer making proper contact with the cartridge chip.
Try removing both cartridges, unplugging the printer from power for 5–10 minutes, then reconnecting it and reinstalling the cartridges. Also inspect the carriage contacts carefully for bent pins or ink buildup.
If the printer still reports "Ink Cartridge Failure" with multiple genuine HP cartridges, the cartridge carriage or printer electronics may have failed. Unfortunately, this is not uncommon on older OfficeJet models and may require professional repair or printer replacement.
Have you tried installing the old cartridge again to see if the printer recognizes it, or does it show the same error with every cartridge?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Sonya さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 30
過去 30 日: 103
今までの合計 22,627
