メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Casio製の関数電卓。低価格でありながら高品質であることから、世界中の学生に広く利用されている。
Facing Problem on my calculator
My calculator is fully reversed. The number is reversed. Everything is rotated into 90 degree. How can i fix this problem?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
6 件のコメント
20°56°its answer plz solve
さんによる
shift button is working only for offing the calculator not for other usages…
さんによる
Has anyone encountered getting the wrong answers when there is a logarithm? Tried to on and off at first and worked but it doesn't work now, also tried resetting but it didn't help.
さんによる
@Anfernee Jinang When you have different symptoms you should ask a new question rather than posting as a comment under an existing question.
さんによる
Also there are only 3 modes left and the rest of the modes just got vanished.
Shift+7 Function is also not working any more.
Please help me
さんによる
1以上のコメントを表示
コメントを追加
3件の回答
最も参考になった回答
If you have not tried the reset sequence here it is…
(CLR)
(Setup)
(Yes)
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
No.Still it's not working.I already did this work.My full calculator screen is reversed.
さんによる
コメントを追加
How's it going I'd like to try to help you fix your device so there's not a factory reset button on the back of it but you could try hitting shift 9 to enter the list then press 3 to reset all and then the equal sign to confirm it then hit the AC button to return it to normal then shift AC to turn it off reboot it see if it works like that then if that doesn't work you may try to take out the battery and getting a paperclip so the positive and negative terminals can reach each other that will help take out some extra electricity let it sit for 5 minutes then replace your battery
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
This actually worked for me.. I took of the battery after resetting all and Voila!! it normalized. Thank you for this.
さんによる
Hopefully that will help if not please let me know and I will be happy to continue finding things to help you out
さんによる
It is not working
さんによる
コメントを追加
Restart it change the battery
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
tanni tanni さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 11
過去 30 日: 54
今までの合計 9,973
