メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2.0GHz Intel Core 2 Duo T7500、最大4G RAM、15.4インチTFT LCDスクリーン、802.11a/b/g/n WiFi、NVIDIA Quadro FX 570M (256MB) グラフィックス
No display on laptop
There is no display occurring on my lapty screen
beep sound are as follows
oneshort beep pause three short beep pause four short beep pause three beep
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
3 件のコメント:
you may have errors with two things basically Dual In-line Memory Module
and system board check them if any one will found faulty replace the part
さんによる
@nmitt start by connecting an external monitor and see if it displays anything.
さんによる
Like when I plug my laptop into the charger, it doesn't work and the current is coming to the laptop but it doesn't work.
さんによる
コメントを追加
1 件の回答
That beep code symbolizes memory failure, and or video failure.
Replacing the RAM should fix your issue.
You have 2GB of RAM preinstalled unless you replaced it.
https://www.amazon.com/dp/B00C538B56
In that link you can buy a 4GB kit, of the RAM that your laptop supports and fits. It is actually more RAM than you have now.
2GB x2 sticks. Try doing so. Pretty cheap as its old ram models. Only 17$
Could be cheaper on EBAY as well. Just makes sure it is that. (The link I provided)
PS. This should fix and boost your Laptop.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Nmitt さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 17
今までの合計 515
