メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Suzuki Motor Corporationが製造するオートバイの修理ガイドとサポート。
Regulator/ rectifier location on 1980 GS1000
Please tell me where my rectifier is located on my 1980 GS 1000. I cant find any website that tells ! Thx!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
Need far more information than you have given!…However a rectifier as it’s name implies changes something?.
If this is a electronic device GS1000 you might be thinking of a component that changes AC to DC.?
さんによる
If this GS2000 is driven by a PSU then a rectifier will be found after the input of AC
さんによる
コメントを追加
2件の回答
最も参考になった回答
Hi @bozmandan ,
Here’s a link to the relevant page in the service manual that describes how to test the regulator. The following two pages elaborate on how to test the rectifier.
They’re probably combined in the same housing.
Admittedly it doesn’t state where the regulator/rectifier unit is actually located but it must be very close to or a part of the alternator. There should be 5 wires attached to the rectifier, Yellow, White/Red and White/ Blue from the alternator, Red from the battery and Black/White from earth and also a Green/White coming from the alternator as well which goes into the regulator section. so it should be easy to spot.
Hopefully this is of some help
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
The rectifier/regulator is located under the rear of the engine just in front of the back wheel. It faces the ground. It’s the thing with the cooling ridges on.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Mine is on the bottom of the battery box
さんによる
コメントを追加
回答を追加する
bozandshaz さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 21
今までの合計 1,056
