メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
1999年に発売。初代PowerMac G3の後継機。300-450 MHz、64または128 MBのRAM、6または12 GB HDDを搭載。
This one is a doozie...
I wanted to see if I could run a very early version of Linux on this Mac, so I got an installation disk for Linux. I tried to boot from the disk, to my surprise nothing was showing up on the TV that the Power Mac was connected to. No grey screen, no boot menu, nothing, even though everything else appeared to be operating fine inside the Power Mac.
Here’s what the diagnostic LEDs are showing inside the Power Mac.
Did I brick my machine by trying to boot from this installation disk? Did my graphics Card die?
Things I I have ruled out:
  • The VGA cable is fine, I tested it with my Mac mini and it worked.
TL;DR: Screen is black, but startup chime is present, fan is running, and 2 LEDs are lit after trying to boot from a linux installation disk.
@mayer ideas?
Update (11/03/2018)
Is this the CUDA button I am looking for? I cannot distinguish between them. Tried pushing both of them, the one on the right made the Mac power on and off, the other one on the left made the Mac do the boot chime and made the optical drive rev up. Still no dice when it comes to the display, there’s nothing being shown. No flashing folder, no grey screen, nothing.
画像
I removed the PRAM battery for 30+ min and that didn’t help either.
@mayer
Update (11/05/2018)
CUDA button was a no-go. I left the PRAM battery out for a full day now, thats a no-go too. Boots up, fans are running, optical drive operates, but no video. One thing I have noticed is before this incident happened, on boot up ALL of the LED’s on the logic board either stayed lit or blinked after booting up. After the linux incident only 2 of the 4 LED’s stay lit after the initial boot up. Could this be a sign?
I am leaning towards a graphics card issue. I just don’t want to be pouring money into unnecessary places.
Update (11/08/2018)
I am afraid that this machine is a brick now. I'll try a new GFX card as a last resort.
Update (11/14/2018)
A new Graphics Card didn’t work. This machine is officially a brick.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
4件の回答
ベストアンサー
Linux requires an Intel processor. Yours has a Motorola and will only run an Apple OS. Hang on I’ll find out which. If you don’t have it, email me your address and I’ll burn an installation disk for you and ship it. Then tell me what other types of software you want and I’ll - never mind, I have it all, it’s just a matter of dragging it out.
Pre-Installed MacOS:8.5.1, 8.6*Maximum MacOS:X 10.4.11
MacOS 9 Support:Boot/Classic ModeWindows Support:Emulation Only
Details:All Power Macintosh G3 models are capable of booting Mac OS 9 and using Mac OS 9 applications within the Mac OS X "Classic" environment.
https://everymac.com/systems/apple/power...
350 MHz PowerPC 750 (G3) processor with 1 MB of backside cache, 64 MB or 128 MB of RAM, a 6 GB or 12 GB Ultra ATA/33 hard drive, a 32X CD-ROM drive or a 5X DVD-ROM drive, and an ATI Rage 128 GL graphics card with 16 MB of SDRAM.
このアンサーは役に立ちましたか?
スコア 5
15 件のコメント:
@mayer Check your inbox, theres an email from me on its way. Unfortunately, this disc seems to have ruined my Mac. However, the GFX card could have possibly crapped out coincidentally. I tried to do a PRAM reset but I could not get it to work.
さんによる 共有
See if there is a CUDA button on the logic board to reset it. Pull the battery so it looses it's mind and memory of the insult of the linux trauma you subjected it to.
さんによる 共有
I just saw your video and the CUDA button is grey and located just to the upper right hand corner of the heat sink.
さんによる 共有
@mayer Take a look at this website, it’s showing something different then what you said. The system powers on fine, the only thing thhats wrong here is that there’s no video. I have a hunch that the GFX Card is kaput.
http://www.macusersguide.com/tag/powerma...
さんによる 共有
@unsubstantiated It's considered polite to say why when you down vote an answer.
さんによる 共有
10件以上のコメントを表示
コメントを追加
Did a new graphics card work? That would be my guess as to why your Mac won’t display anything but appears to run fine.
Other then that, I think your Mac might be “bricked”. Incompatible installation discs tend to ruin PowerPC computers and that might be what happened here. Sorry bud.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Yes, I have tried a new graphics card and it is a no-go. I am considering doing a case mod with the outer shell. Frustrating!
さんによる 共有
コメントを追加
One simple answer, apple did not configure their products to run Linux too. If you teardown a pc made to run Linux and an apple pc, you will find the basic parts the same but many supplementary parts too that the PC made to run Linux needed that the apple pc had.
このアンサーは役に立ちましたか?
スコア 0
17 件のコメント:
@luckytechguys I get that, I was just curious if I could boot from that drive. As soon as I put the installation disk in the optical drive all of this nonsense happened. Screen is black, but boot tone is present, optical drive operates, fan is running, and 2 LEDs are lit.
This isn't helpful at all, and it is somewhat off topic, sorry.
さんによる 共有
No problem, try booting on apple os and seeing if the PC is still working. If it is then you know Linux will not boot. If not, booting on linux screwed with the computer too.
さんによる 共有
Before this issue occurred I was able to power on the Mac and have it at least get to the flashing folder icon. My hard drive died on this computer and I don't have a drive. All I know is that this computer was running just fine before trying to boot from this installation media.
さんによる 共有
another recommendation, see the system requirements for the Linux version that you are trying to run. Compare them against your hardware. If the PC doesn't support the required system hardware, Linux will not boot. If this is the problem find a version compatible with all of the system specs you have.
さんによる 共有
and what was the version of linux you were trying to run?
さんによる 共有
12件以上のコメントを表示
コメントを追加
I know this is old but in case it helps someone...
If someone were to try booting a Linux install disc, it just won't boot from the disc unless it supports PowerPC, and if the machine boots of a disc, it won't stopt the machine from booting normally once the disc is removed.
If the machine chimes, it has passed a few basic checks already. Some indicators of how far is has made it through the power on test can be identified by watching the LEDs and error sounds.
画像
The red circled LEDs are the IDE activity LEDS, they should blink when the drives are accessed, if you see them blinking (5-20ish seconds) after the chime, the system is booting, even if you can't see anything on the display.
If there is no activity there, check the USB LEDS (orange circle), the service manual and my working system turn these on near the end of the power on tests and initialization. If they don't turn on, the system is stuck on something before the end of the startup initialization.
The green circled led shows when the CPU has asserted control of the bus, it comes on solid while the CPU is in reset and then may be seen to blink faintly if the CPU is executing code.
If you remove the memory you should get a error tone instead of the chime.
Try removing the video card to see if the LEDs behave any differently, also try disconnecting the ide cables to see if there is any difference in the behavior (ie. if the USB LEDs didn't come on, do they with things disconnected.
Also try with all mice, keyboards etc. disconnected.
Check the voltages at the power connector with a multimeter.
Orange is 3.3v, red: 5v, Yellow 12v, Blue: -12v, Purple: 5v Standby
Video cards need to have Mac firmware, so any replacement card needs to be from an old Mac, or have appropriate firmware flashed, but a known good one would be best for trying to resolve the no video problem
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
[deleted] さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 50
今までの合計 2,072
