メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Recreational Active Vehicle with 4-Wheel Drive(一般的にRAV4として知られる)の第2世代モデル。
How do I reset the TPMS
I have 2010 RAV4 that had one TPMS-Sensor replaced. The TPMS Warning Light will not clear, even after driving 50+ miles. There is NO TPMS RESET button on this vehicle. How do I reset this ? Is there a fuse that can be re-seated? Thanks.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
3 件のコメント
https://www.moderntiredealer.com/article...
htt ps://w ww.mode rntiredealer.c om/article/715783/tpms-toyota-2006-2012-rav4 (remove the spaces)
AKA, go to Costco tire center and ask them :)
さんによる 共有
How to test the sensors and how many sensores are there in the engin of Raf4 model 2004
さんによる 共有
@mahaddable one in each tire and that includes the spare. That means there should be five sensors.
さんによる 共有
コメントを追加
1 件の回答
ベストアンサー
Is the light flashing?
Here is a video on fixing it if the light stays on: https://www.youtube.com/watch?v=kbdlypWm...
このアンサーは役に立ちましたか?
スコア 3
4 件のコメント:
I am looking for location of TPMS RESET Button. It is not under dash, not on dash, not in glove compartment. This is a 2010 Rav4 Limited (4WD). All pressures are good. Had replaced TPMS Sensor in one wheel because it was leaking after new tires put on. TPMS Warning Light flashes when engine starts, then it stays on steady. Thanks.
さんによる 共有
Check the pressure in the spare tire. Tires should have min 32 PSI. See if your reset button is located under the dash, see second 18 of this video:
https://www.youtube.com/watch?v=R25t0lqU...
さんによる 共有
Have to register the sensor with the computer of the vehicle with some tool. ( it seems).
Go to Costco tire center and ask them.
さんによる 共有
Worthless video for lights that stay on after all 5 tires are aired up. Video says “take it to the dealer for service".
さんによる 共有
コメントを追加
回答を追加する
Janek Lachkovich さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 54
今までの合計 6,425
