メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
The Kenmore Elite HE3 is a washing machine by Kenmore. It is identical to the Whirlpool Duet.
Washer F06 error code Randomly
Hello,
My washer seems to get a F06 error code on certain wash cycles. The error code randomly shows up and sometimes won’t go away for days and not finish a cycle. Most of the time it will always finish the hand wash cycle with no issues but all other cycles won’t even get past the first 5 minutes.
After disconnecting the power for almost a day the washer worked fine for two days on all cycles and has now just started getting the same error code.
All electrical connectors were found to be secured and control boards were found with out any sign of burn marks or failures .
Any troubleshooting tips or what i should replace would be appreciated
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Check out the link below, someone had a similar question and it was answered by multiple people. Hopefully someone’s answer will be of help for you.
f o6 error code
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Bryce Mcpherson さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 6
今までの合計 884
