メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
Battery not charging after DIY repair.
Hi,
My wifi signals were very weak so I decided to replace wifi flex cable. Using ifixit app I read the tutorial and fixed it. I was quite happy but later on realised phone is not charging. I opened my iphone again and checked if all cables are attached and they were perfectly placed. I switched off my phone and connected charger it powered ON but again it wasn't charging. Please help me. And also tell me which cable transfer current to battery. Maybe,I would have dislocated something.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
3 件のコメント:
@aatif667 Do you have a computer running macOS/OS X handy?
さんによる
Yes.. i have macbook pro
さんによる
I put it on charge for an hour now its taking charge. But now comes the other problem. Touch and screen is working fine. But while powering off I can't slide that to power off.
さんによる
コメントを追加
1 件の回答
iPhone 6のバッテリーの交換
Step 12 shows you the battery connector. Check that connector. You also could have damaged something in the process.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
AATIF ALI KHAN さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 70
