メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Asus ROG Strix GL702VM-BHI7N09は、Asusが2017年1月に発売したゲーミングPCです。
Touchpad not Working in windows 10
Good Day. I actually have an asus GL504GM whitch is not listed here. Ive installed the latest windows from Microsoft, updated to the latest version, but the touch-pad/track pad is not working at all and not found in device manager. I’ve downloaded the latest driver found on Asus website but i receive an error when trying to install it. “There is a problem with this windows installer package”
Update (10/27/2018)
Good Day,
Thank you for the reply.
Please note that - no old drivers found. ATK Package - unable to install because the setup is not applicable to your computer
EDIT: in bios the touchpad is working so its not a hardware issue
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
6 件のコメント
Hi,
Apologies may have got it wrong
Is this the touchpad driver that you tried? (select your model and OS)
In Device Manager are there any yellow exclamation marks or red crosses that may indicate faulty or disabled hardware
Check for "hidden devices" in Device Manager, just in case it is listed there. Click on View tab > show hidden devices
This link may also be of some help.
さんによる
Yes, thats correct, those are the drivers i have tried. Selected windows 10(the only option) and GL504GM - my model
i don't have elan driver so it does not work.
No Yellow exclamation mark except Intel SD Host controller.
Its Not listed under Hidden devices in device manager.
さんによる
In windows settings under the devices tab i only have mouse, no touchpad or trackpad. Same thing in the device manager
さんによる
Hi,
OK.
More things to try ;-)
Check in BIOS under Security tab > I/O Interface Security whether there is an option to enable or disable the touchpad.
Try doing an Windows update check again. Settings > Update and security > Windows Updates > Check for updates.
Try doing a Startup Repair and see if that works.
Settings > Recovery > Advanced startup > Troubleshoot > Startup repair
If still no good you may have to revert back to the previous Win 10 version.
Settings > Update and Security > Recovery > Go back to the previous version of Win 10.
さんによる
In bios touchpad is enabled.
No other Windows updates available.
I'll try the startup repair but I don't think that will work.
Maybe the rollback to a previous Windows version might work
さんによる
1以上のコメントを表示
コメントを追加
4件の回答
最も参考になった回答
Found it!
you need to install Serial i/o from intel before installing the drivers for the touchpad
download here :
https://dlcdnets.asus.com/pub/ASUS/Gamin...
or in “others” section
このアンサーは役に立ちましたか?
スコア 4
2 件のコメント:
YESSSSS!!! THIS RIGHT HERE! THANK YOU, THANK YOU, THANK YOU! I actually didn't have to mess with the drivers, one stated an error and mentioned the item you've recommended, a simple download, extract and executable later and I'm good to go! :D
さんによる
It worked for me too, thank you!
さんによる
コメントを追加
You dont have correct device driver for touch pad. I will appear as unknown device. Find mother board dvd for driver or find windows driver for touch pad. Any default touch pad driver will work.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
There is no motherboard DVD included in the package.its a laptop without DVD rom.
さんによる
try usb pendrive for driver go to control penal and click on add remove windows component and install driver for touch pad.
さんによる
コメントを追加
Had this same problem when I resetted a newer model asus and hp laptops. Fix it by downloading Microsoft Windows 10 Update Assistant from microsoft website. It loads the latest win 10 version which fixed the problem on both.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Fix Windows 10 Touchpad Issues
Touchpad issues can either come from the hardware or the drivers powering it in Windows. Once you track down which it is, solving the problem is straightforward. These steps can help you narrow the cause and get your touchpad working.
Confirm that the trackpad is connected properly. If your touchpad is not working, make sure it's connected to the Windows 10 device properly. If you use a touchpad that connects through USB, check that both ends of the connecting cable are fully plugged in.
If the touchpad is part of the keyboard, like with the Type Cover on the Surface Pro and Surface Book, make sure that the keyboard is completely connected to the tablet with no foreign objects obstructing the connecting prongs.
If your touchpad and keyboard are built into your system (like in a laptop/notebook), this is more difficult. Skip to step 5; if the further steps do not help your issue, you may have a hardware issue and may want to bring your system to a computer repair shop.
Remove and reconnect the touchpad. Unplugging and reconnecting the touchpad may fix connection issues. If you use a Type Cover on a Surface device, this can be done by disconnecting and reattaching the Type Cover.
Check the touchpad's battery. If the touchpad connects to the Windows 10 device using Bluetooth and it stops working properly, its batteries might be running out of power. Replace the old batteries with new ones to see if this fixes the problems you experienced.
I hope this information will be helpful!
Mark Wilson
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Catalin Parvu さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 25
今までの合計 8,660
