メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Logitech G602(ワイヤレスゲーミングマウス)に関する背景情報。
Mouse wheel is not scrolling
I have a problem with my mouse scroll wheel. The scroll is not working at all but the wheel clicks just fine.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
1件のコメント
I have recently started having this problem. I was sold it as brand new. It was working and it just stopped scrolling. Middle button works, but no scroll. There's no dirt or anything.
さんによる
コメントを追加
6件の回答
最も参考になった回答
Logitech G602 スクロールホイールの交換
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
@ramirocampa Thanks for your help. The problem is not in the mechanical side of the scroll. When I scroll the wheel, it rotates well. The issues is that rotation doesn't get captured or sent to the computer i.e. no action happens
さんによる
it might be a problem between the wheel and the digitizer. usually back in time there was a digitizer usually near the axis of the wheel. i dont know if it is suitable in your case but you might take a look at the "gears" or anytype of physical damage between the axis of the wheel and the support of it. in other mouses may be a worn out plastic axis... instead of being square shaped or any desired form it may be damaged (like too roundy) i hope this helps.
Regards
さんによる
コメントを追加
I had the same issue. Took it apart, and found the wheel clogged up with cat hair. Cleaned that up and it’s working again. Thanks for the pics on how to get it apart though :)
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
scroll wheel was intermittent. Opened as above, removed ball of lint with tweezers from wheel area. Immediately worked correctly. Spudgers not necessary for this repair. Fingernail worked great.
PERFECT answer for my variety of this problem!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
First i was thinking it doesn't work because of software. I uninstalled everything, but it didn't help .
Thank you. was dirty inside. fixed
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Open it up (look for a yt tutorial if in doubt) and take it from there
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Well I will suggest you to check out the following: https://www.systweak.com/blogs/logitech-...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
eng_m_hamda さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 15
過去 30 日: 63
今までの合計 8,304
