メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Fordの第10世代F-Seriesである、F-250 Heavy Dutyピックアップトラックの修理ガイドとサポート情報。
Cranking but won't start
Engine shuts off like no fuel. Cranking but will not start
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Hey, Doug. As you said, it could not be getting any fuel. Turn the key to the run position and listen for a humming noise near your gas tank. If you hear the fuel pump, you’re most likely getting fuel. Next I recommend checking for spark. Do you have a spark tester or the tools to remove one of your spark plugs and some spare wire?
このアンサーは役に立ちましたか?
スコア 3
6 件のコメント:
I have and also found whenever I shook the bed of the truck stirring up the gas it would start and run for a minute then cut off??
さんによる
Hi,
Have you checked that the fuel filter is not clogged with debris?
さんによる
Yes I have... put a new filter on about a week ago
さんによる
That's interesting. You may have debris in the tank. I would try putting some fresh fuel in the tank and see if it will start/run a little better. The in-line filter you changed isn't the only filter in the fuel system. There's a "sock" filter on the pickup tube in the tank. This filter can get gummed up by old gas or trash. If there is trash floating in the gas, it should be floating at the top. Adding some fresh gas might displace that trash. Let us know if it seems to run any better.
さんによる
The tank was clean as a whistle... the fuel pump was the problem. Running great now. Thanks
さんによる
1以上のコメントを表示
コメントを追加
回答を追加する
Doug Tretter さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 20
今までの合計 978
