メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Canon EOS Rebel XSiの修理ガイドとサポート。2008年に発売された12.2メガピクセルのデジタル一眼レフカメラです。EOS 450D、およびEOS Kiss X2としても知られています。
How to fix the lcd display?
The LCD display does not function - it just shows white lines. I see a guide for replacing the LCD, but where do you find the LCD for replacement. The guide shows “no parts needed”.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @griffoso ,
LCD screens replacements are available online.Just search for Canon EOS Rebel XSi/450D LCD screen part to get results for suppliers.
Here’s a link to just one supplier. It is shown only to give an indication of the price of the part. There may be other suppliers that suit you better.
このアンサーは役に立ちましたか?
スコア 3
3 件のコメント:
Great, thanks. I’m thinking it’s likely that it’s the lcd screen that has failed here. Do you know if there is anything else that might cause the display to fail?
さんによる
Hi @griffoso ,
Try taking some pictures, (I realize that you can't "see" what you're taking) and download them to a computer.
This is to check that the problem is only with the LCD screen. (I assume that you cannot view any menu screens either?)
If the images are OK then most likely it is a LCD screen problem.
If there are only black images being shown on the computer, then perhaps there is a problem with the image sensor in the camera, the motherboard or both.
If this is the case (black images downloaded) has the camera been dropped or gotten wet at all?
さんによる
Thanks for the info. Yes, I’m able to take pics using the auto setting, so it’s likely the lcd screen. I really appreciate the help.
さんによる
コメントを追加
回答を追加する
Bruce さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 11
今までの合計 543
