メインコンテンツにスキップ
2015年9月25日にAppleから発売されたiPhone 6Sの修理情報とガイドです。モデル A1688、A1633。
2693回答 すべてを表示
No display after replacing charger port
I have an iPhone 6s. It would only charge if I bent the lead so I ordered a replacement charger port. I stripped the phone and fitted the new part but now my phone won't turn on. Well, I think it's on because I hear alerts but nothing on the screen. I thought it may be a problem with the screen but nothing shows up in itunes either. If I hold home/power itunes then says it needs to update. I updated it and it says it would show after update/reboot but doesn't.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Were you careful to disconnect the battery before reconnecting the screen? I’m going to guess “nope, didn’t know you had to do that” in which case this is classic iPhone 6s backlight problem. Head to your friendly local microsolderer or mail in repair service to get your logic board fixed up for blown backlight filter.
Jessa
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
All the tutorials I watched re-connected the battery before connecting the screen
さんによる
You can't believe everything you see on the internet ;>). Trust Jessa, you want to disconnect the battery before playing around with the screen connectors. Check out the iFixit guide, it clearly shows the battery being disconnected early on in the process.
IIRC, Jessa was advocating for this addition to all the guides several years ago.
さんによる
コメントを追加
回答を追加する
ph4ntom99 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 9
今までの合計 86
