メインコンテンツにスキップ
Released May 2012, identified by model number J2011-03-US.
45回答 すべてを表示
My Jawbone Isnt Responsive To Me With Or Without Charger
When i hold the button on my jawbone speaker it doesnt turn on or light up, i plugged it in and nothing all i got was a very quick flash of red and i tried to turn it on while it was on the charger still nothing, i listen to it all the time what has happened
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Sadly you likely have a dead battery or the micros USB connection is bad. You can find the needed battery, but the micro USB socket part is hard to find as Jawbone is out of business. Some people have managed to fit other sockets with a bit of work. First test your battery following this guide to get to the leads: Jawbone Big Jambox Battery Replacement if the battery is dead then you’ll need to replace the battery and you’ll then need to check the charging logic as well.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Al-Terrah さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 84
