メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Jawbone Big Jambox Battery Replacement
必要な工具と部品
    1. Jawbone Big Jambox Battery Replacement, Outer Case: 手順 1、 1の画像 1
      • Remove both end caps by putting a plastic opening tool in the center of the seam. Work around the edges to pry the end caps off completely.
      • Due to interior clips holding the end caps in place, use caution when applying force.
      FixBotに聞いてみる
      コメントを追加
    2. Jawbone Big Jambox Battery Replacement: 手順 2、 3の画像 1 Jawbone Big Jambox Battery Replacement: 手順 2、 3の画像 2 Jawbone Big Jambox Battery Replacement: 手順 2、 3の画像 3
      • Turn the Jambox upside down. Peel the indicated rubber tabs off, using a plastic opening tool if necessary.
      • You may want to only take the tabs half way off to avoid re-gluing when reassembling.
      • Remove the three T6, 7.0 mm screws under each rubber tab.
      • Because the screws are a different length, set the screws aside.
      FixBotに聞いてみる
      コメントを追加
    3. Jawbone Big Jambox Battery Replacement: 手順 3、 3の画像 1 Jawbone Big Jambox Battery Replacement: 手順 3、 3の画像 2 Jawbone Big Jambox Battery Replacement: 手順 3、 3の画像 3
      • With the Jawbone logo facing towards you and with correct orientation, place the Jambox with the left end cap facing upward.
      • Unscrew indicated T6 9.7 mm screws.
      • Gently loosen the tabs from their anchor points so the bottom may be removed.
      • Flip the Jambox so the other end cap is facing up. The USB cable is on this side (metal grounding clip, indicated in orange). Repeat the above two steps.
      FixBotに聞いてみる
      コメントを追加
    4. Jawbone Big Jambox Battery Replacement: 手順 4、 1の画像 1
      • Pry up the bottom panel by lifting from the device.
      • Pull the bottom up. This may take a bit of force as the bottom is glued to device.
      • Once removed, the battery will now be visible.
      FixBotに聞いてみる
      コメントを追加
    5. Jawbone Big Jambox Battery Replacement: 手順 5、 2の画像 1 Jawbone Big Jambox Battery Replacement: 手順 5、 2の画像 2
      • Before unscrewing, take a picture of the top view. That way, when you're reassembling the device, you'll know the orientation of the metal grounding plates.
      • Unscrew the eight indicated T6 9.8 mm screws. Remove metal grounding plates.
      FixBotに聞いてみる
      コメントを追加
    6. Jawbone Big Jambox Battery Replacement: 手順 6、 1の画像 1
      • Once all eight screws are removed, pry the sides of the Jambox to lift the body from it's shell.
      FixBotに聞いてみる
      コメントを追加
    7. Jawbone Big Jambox Battery Replacement: 手順 7、 1の画像 1
      • With the battery facing forward, remove the three indicated T6 9.5 mm screws.
      • Once the screws are removed, lift up the small plastic plate, revealing the auxiliary board underneath.
      FixBotに聞いてみる
      コメントを追加
    1. Jawbone Big Jambox Battery Replacement, Battery: 手順 8、 2の画像 1 Jawbone Big Jambox Battery Replacement, Battery: 手順 8、 2の画像 2
      • Remove the indicated T6, 7.4mm screw holding the auxiliary board in place.
      • Carefully lift the circuit board up and off to the side.
      FixBotに聞いてみる
      コメントを追加
    2. Jawbone Big Jambox Battery Replacement: 手順 9、 1の画像 1
      • Pull on the red and black cables under the auxiliary board to disconnect the battery.
      FixBotに聞いてみる
      コメントを追加
    3. Jawbone Big Jambox Battery Replacement: 手順 10、 2の画像 1 Jawbone Big Jambox Battery Replacement: 手順 10、 2の画像 2
      • The battery is connected to the Jambox with double-sided sticky tape. Use your finger to pry out the battery.
      • Place a new battery in the old battery’s place. Reverse these steps to connect the new battery.
      • When plugging in the new battery, ensure the red and black wires are separated around pegs so that they are not pinched when the auxiliary board is replaced.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
69 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Abby Cybula
メンバー登録日: 04/01/15
2,038 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 24-5, Lancaster Spring 2015 Cal Poly, Team 24-5, Lancaster Spring 2015人のメンバー
CPSU-LANCASTER-S15S24G5
4 メンバー
25のガイドは作成済み
33件のガイドコメント
Where do I buy the battery.
Kevin Foti - 返信 共有
http://www.ebay.com/itm/322588700358?ul_... :Here is someone who made and sell the battery for Jambox and Big Jambox, i hope this could be helpful
Lin - 返信 共有
да где аккумулятор купить то?
speedlexx - 返信 共有
на рынке покупаются стандартные 18650 и меняются на старые акку из колонки. что б пошла зарядка нужно дать больше ток.
цена вопроса ~ 1200₽ с работой
Max - 返信 共有
Where do I go to purchase a battery?
Edward Brown - 返信 共有
コメントを追加
統計データ:
過去 24時間: 11
過去 7 日: 63
過去 30 日: 284
今までの合計 75,295
