メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Dyson DC08は、Dysonが製造する掃除機です。
I think machine has blown fuse
I think machine has blown fuse. The cord got caught while vacuuming, stopped and will not turn on again. There was no noise or burning smell. Nothing to indicate motor failure. The cord is undamaged. I suspect the machine plug became dislodged from the power socket or something similar to make it blow a fuse. What type of fuse do I need please? Is this something an electrician could fix as I live in a remote area , need the machine for daily use for medical reasons and for medical reason cannot use another machine in the meantime until this one is fixed.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
3 件のコメント
Hi,
After fiddling with the actuator and power cord the machine works again , and it the cord is at a certain angle the machine stops until the angle is corrected. So I think you are right, the issue is with the power cord. Question: Would it be possible to fix the wiring within the cord retract as I cant find a replacement cord retract as dyson no longer stock parts and I have been unable to source elsewhere.
さんによる
Hi,
さんによる
can somebody please help me. The machine stopped working again. I fiddled with the cord and something blew around the area where the cord comes out from the machine. I need t vacum daily for medical reaon and cannot borrow or buy a ne w vacum for medical reasons.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Hi Gemma,
Please look into this post: How do I replace the damaged power cord
It lists the disassembly instructions for the power cable retraction system - along with replacement.
When reviewing your symptom and “possible” cause being “cable-displacement” - THIS REALLY STOOD OUT! I hope it helps some.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
gemmababe29 さん、ありがとうございました!
統計データ:
過去 24時間: 10
過去 7 日: 18
過去 30 日: 27
今までの合計 1,825
