メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2016年9月16日発売。モデル番号1660、1778。GSM版またはCDMA版が利用可能 / 32、128、256 GB / ローズゴールド、ゴールド、シルバー、ブラック、ジェットブラック。
Activate issue with no network works
Hello!
I have iphone 7 (A1660) with (NO service) problem , I tryed use ipcc files but carrier still Not Available, so I update to IOS 12 and now I stuck with activate issue(there is still no service,Even with use different sim cared), it saying Unable to Activate An update is required to activate your iphone. image below
画像
I Noted when I eject the tray of sim cared, my phone do’s not say (No SIM card inserted ).
pleas help me!
Thank you before!!
Ibrahim
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 15
1件のコメント
I have same problem too
さんによる
コメントを追加
8件の回答
最も参考になった回答
I solved that issues by changing BBPMU IC on iPhone 7 and restore via iTunes then my problem solved.This videos help me to find the solution.Hope this works.
このアンサーは役に立ちましたか?
スコア 3
3 件のコメント:
where is the video? I really need your help sir, I got this problem for a month now
さんによる
where is the video
さんによる
@aresmuzamel
@MAKE
Click on solution to get video
さんによる
コメントを追加
This is a known issue with the iPhone 7 modem. Send in for repair with Apple: https://www.apple.com/support/iphone-7-n....
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Apple says the fix it for free until you send them the device. I had the same issue and Apple says that my iphone needs a new screen due to a very little scratch and they are charging me 316+tax for that, so they fix the activation issue. Bottom line, they fix everything with the phone or nothing, you have to pay for the cosmetic issue so they fix the activation issue for "free". Scam
さんによる
コメントを追加
I had this issue with iPhone 7.
Did a chat with apple representative and they had me go to my iTunes and make sure I was updated first. Then turn phone off and connect to computer. Then open iTunes and let it install update.
It didn’t work.
She next had hold down the power and volume up button for about a minute or two until your phone shows that it is connected to iTunes, then the iTunes screen on my laptop was showing that it was extracting, then when it was done it started to update.
Phone turned off after installing and I was able to set my phone up.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
some people with this case get their phone back with changing baseband power ic on the machine board. May be y’all wanna try it too.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
ich habe problem men iphon gleich ist was maen bite
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
if the model is of those : A1660, 1680 , A1779 then there is no issue coz apple said it, you can read this link :https://support.apple.com/iphone-7-no-se...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Fixed by adding another device to my account(iphone 6) then i removed my iphone 7 from list of trusted phones. That allowed me to activate.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
could you explain it a little bit more?
さんによる
コメントを追加
My iphone 7 unable to activate
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Ibrahim Hassan さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 21
今までの合計 21,980
