cord does not fit
the part of the cable which should fit in the kindle is not fitting. it seems to be blocked. it is the correct cable
Alright, so let’s check out the port area and clean it from any obstruction that may be blocking the cable from charging your kindle. Also, could you please upload an image of what the charging port looks like? iFixitでの質問に画像を追加する方法
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 4
過去 30 日: 10
今までの合計 530
3 件のコメント
@einekels Try a different micro USB cable just to be sure it is not the cable, because the cable could just be a little bit deformed.
[deleted] さんによる
@einekels carefully check the cable on either end as well as the board connector. See if you have any bend or broken pins etc.
oldturkey03 さんによる
There is a piece of plastic fixed in the charging port. The paper white kindle is about a yr old but only used on holiday so not been used much this is the first charge for it.
linda.cartlidge さんによる
