メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Insignia Flex 8は、Tianshi Digi-Landoが開発した多機能タブレットです。インターネット接続、写真撮影、アプリの使用が可能です。
I Forgot my log on pattern
How do you recover your logon pattern? I forgot mine.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
1件のコメント
insignia tablet forget pattern
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Sadly you will have to factory reset your tablet in order to be able to use this tablet again. Factory resetting your tablet will erase all data stored on your tablet.
Ensure the tablet is connected to the charger and has at least 45% battery left. If the battery dies during this process the device could be damaged.
  1. Power off the tablet fully.
  2. Press and HOLD the Volume + button.
  3. While still holding the Volume + button, press the Power button until the screen illuminates and shows Insignia.  Then release the power button only
  4. Continue holding Volume+ until one of two screens appears
  5.   A) -A screen appears with only an Android mascot in the background. If this happens simply let go of volume + and press it one time.  You should then see the screen shown in item 'B'
         B) - A list of options in the top left of the tablet screen.
Six - Use Volume - to select "wipe data / Factory reset" and press the power button to select it
Seven - Use Volume - to select "Yes -- delete all user data" and press the power button to select it.
Eight - Following the reset, the device should boot up and go through the initial setup process again as when it just came out of the box.
Feel free to ask questions!
このアンサーは役に立ちましたか?
スコア 2
6 件のコメント:
My laptop reset list is in Chinese which one is the factory wipe/reset
さんによる
this won’t work for me
さんによる
My screen doesn't look like that it all blue with different options and it says I don't have enough space to reset my laptop
さんによる
What do I do if it says there is not enough space to reset the laptop but I can't log in to make space?
さんによる
How do I reset a pin?
さんによる
1以上のコメントを表示
コメントを追加
回答を追加する
Cindy Snodgrass さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 25
今までの合計 8,601
