How can I get a replacement remote control?
この質問は役に立ちましたか?
If you purchased from amazon and have your amazon order id, you can request a free replacement remote to be sent out to you from dbpower (dbpower.co). If you are really nice and persistent (as I was), they may even send you the replacement remote even if you misplaced your order id (like I did). A huge thank you to MJ, Dom, and Ted at DBPower for being so helpful!
The universal projector remote mentioned above is unlikely to work as the user manual does not list that it supports DBPower devices. After i recieved my replacement remote and determined its IR signals, I searched the irdb database for other devices that matched and although none matched exactly (you’d have to press menu for volume up, for example) there are some obscure brands that have used NEC1 Device 2 in products before… so there is at least a possibility that some universal remote somewhere may work a little (likely only by coincidence, and likely only a few buttons would work).
If you have a programmable universal remote, you may be able to use IrScrutinizer to generate the IR codes and export them to something your remote will understand. Logitech harmony users can open a support ticket and provide the pronto hex function codes to them so they can update their database and you can select the device in myharmony as you normally would.
I uploaded the IR code detail to irdb (irdb.tk, also found on github) and Does anyone have the remote control and a way to share its IR codes?
このアンサーは役に立ちましたか?
I believe this universal remote will work for you. Return it if it does not.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 6
過去 30 日: 31
今までの合計 4,627
