メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Dell VRC-100Rは、モデル番号「536-BBBS」で識別できます。2017年10月に発売された、第1世代のBluetooth仮想現実(VR)コントローラーです。
Fixing the trigger on the WMR Controller?
The trigger on my right controller is stuck “pushing in” when I am in VR. I have tried to disasemble the controller to see if there is anything wrong with it, looks like it’s missing something. What could it be missing? I don’t want to disassemble my left controller needlessly to see if it’s missing something.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
Ok…well apparently ifixit thinks my answer is spam. I’ll try one last time:
I think I may have the same issue, and I fixed it. I followed the ifixit guide for doing a touchpad replacement (apparently if I link to that tutorial, this post gets marked as spam, so you’ll have to find it yourself), through step 7, removing the back panel, which contains the trigger. In my case, the small metal rod that holds the trigger in place and allows it to rotate had slipped out of the hole on one side. I wiggled it back in place, and after putting everything back together it worked. It looks like this rod could easily slip out of place. Not sure if this is the same issue for you, but I hope it’s helpful. Best of luck.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
NO PE さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 7
今までの合計 1,110
