メインコンテンツにスキップ
13インチアルミ製Unibody, 2.0 or 2.4 GHz Core 2 デュオプロセッサモデルです。
574回答 すべてを表示
締切られた回答
water spilled MacBook won't charge. it does see the battery
so water spilled on this computer. it will detect the battery, and magsafe will look like it's charging with the orange light but battery remains at 0% (even though battery could be charged 100%) I have the skill to repair the logic board but I need some help in pinpointing where the issue is. any ideas?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
Can you tell me where you found the short and the procedure you used to solve the problem? I have a very similar issue. The battery is recognized and the MagSafe looks as if it's fully charged (green light), but the screen says "Not Charging." Battery is at 0mAh.
さんによる
Can you supply a picture of the logic board between the LCD connector and the tester pins? I don't have the logic board anymore but the symptoms you're describing are the same I had.
さんによる
コメントを追加
5件の回答
ベストアンサー
Here's where to start. Nobody can really tell you what's happened. Electronics Water Damage
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
thanks but i forgot to mention the procedure has already been done.
さんによる
コメントを追加
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I managed to repair the board! I scanned it for a bit trying to find burnt IC's or perhaps broken lines until I finally spotted the short. Jumped and computer is back to life. Not bad for $150 :)
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
That's great, glad you got it running.
さんによる
コメントを追加
What did you mean Josh when you "Jumped the computer"
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
....and can you upload picts of the repair ?
さんによる
コメントを追加
what I mean by jumped (jumpered) the connection - basically replace the broken line by soldering a wire from one area on the logic board to another therefore completing the connection. I need a close up picture to pin point where to jumper since I don't have this logic board anymore.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
That would not work. It would be like turning on your auto ignition switch and engaging the starter motor and not letting it go.
さんによる
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 2
今までの合計 1,924
