メインコンテンツにスキップ
2017年11月4日発売。モデルA1865、A1901。GSMまたはCDMA/64GBまたは256GB/シルバーまたはスペースグレイ。(発音は「iPhone 10」と同じ)。
There’s a black “ink”spot in the bottom right corner of my screen?
My screen has no cracks on it, I’ve dropped it twice.
The first time it landed backside down and I noticed that a small black spot that sort of resembles ink appeared. I dropped it again today, it landed the same way, and the spot got bigger.
I can still control my screen directly on where the black spot is im just not sure what it is or how it could be repaired
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 9
コメントを追加
4件の回答
ベストアンサー
If you could post a picture, we could say for certain but it sounds to me like the actual OLED has been damaged. If that’s the case, then you will need to replace the screen.
If you want a high quality screen replacement, then Apple is still your best bet. However if your housing is damaged, they may refuse to replace the screen, in which case an independent repair shop will be able to replace the screen. Just ask about the quality level of the replacement screen because there are some inexpensive (relatively speaking) aftermarket LCD’s and now aftermarket and premium level OLED.
このアンサーは役に立ちましたか?
スコア 9
9 件のコメント:
Hey does it spread all over after you dropped off ??
さんによる
It's not spread ed it's just down at the last of the month
さんによる
I just wanted to know what the plus was for at the end of the calendar
さんによる
Nothing appears to be damaged it's just got a plus sign at the end of the calendar.
さんによる
I don't believe anything is damaged if it is then the glass and back are a waste of mone
さんによる
4件以上のコメントを表示
コメントを追加
Black splotches inside LCD display are caused by dropping the phone.
To get that fixed you would need to get the hole display replaced. Most expensive phone to get it replaced.
[リンクされた製品が存在しない、もしくは無効: IF377-003]
このアンサーは役に立ちましたか?
スコア 6
4 件のコメント:
Does the warranty cover this type of damage?
さんによる
Does it grow with time on iphoneX?
さんによる
It can get worse over time as it bleeds like ink in a display that expands. This would not be covered under normal warranty as it is considered physical damage.
さんによる
Is there a way to arrest it?
さんによる
コメントを追加
So I cracked my phone at the bottom right corner of my screen and it is showing vertical lines on that side of the phone can I get it fixed?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
You'll need to replace the display.
さんによる
コメントを追加
I think this will be helpful for you
https://okadtech.com/how-to-fix-black-sp...
You can try the solution to solve this problem.
I was facing this issue in my iphone x tried this article solution it didn’t work.
Tried the same solution in a others phone it worked.
Conclusion - If the pixel is dead then you can’t repair it but if it’s stucked then it can repaired.
I dropped my iphone x so maybe the pixels are broken so i unable to solve this problem. I have to replace my screen.
It all differ.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Xandria さん、ありがとうございました!
統計データ:
過去 24時間: 7
過去 7 日: 33
過去 30 日: 210
今までの合計 211,706
