glue for phone screen repairs?
1)can i use crazy glue to glue the digitizer to body frame of my j3 phone?
2)can i use crazy glue to glue the glass to the digitizer?
3) are there glue brands that you would recommend?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
the lcd, glass and digitiser should be all in one. to attach it to the frame either 3m double sided tape or b7000 glue
このアンサーは役に立ちましたか?
Thank you for your response!!
There are glass only repairs as well that can be done. Replacing the glass on the digitizer itself (where the glass is cracked and the digitizer is fine).
for glass only repair you need to use loca glue to bond the glass to the lcd and cure it with a uv light
@ffahami Yes, and no crazy glue at all.
過去 24時間: 0
過去 7 日: 13
過去 30 日: 29
今までの合計 6,556
1件のコメント
I appreciate the help guys!
Jason さんによる
