What should I do if the Apple 6 capacitor screen is broken?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
As @arbaman suggests, it would help if you explained what you meant by capacitor screen. A capacitor is a discreet component that is used within the logic board and is generally not associated with the screen itself. However, the digitizer is based on a capacitive touch interface so I’ll assume that is what you meant.
If the screen is defective, then it needs to be replaced. It is a fairly straightforward repair so you can do it yourself by buying the appropriate parts (the kit has all the necessary tools) and checking this repair guide.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 270
4 件のコメント
What do you mean by "capacitor screen" ?
arbaman さんによる
I believe the OP means "capacitive touch".
Minho さんによる
yes,it is capacitor touch screen
Annaa さんによる
@refectio I've not heard that distinction for quite some time now ;)
arbaman さんによる
