メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Acer Aspire E1-571ノートパソコンの修理とトラブルシューティングに関するヘルプ。
Device seems completly dead
Hello,
I have a Acer Aspire E1-570 (I couldn’t choose it in the devices list) that won’t power on. I chose chkdsk in Win 10 to run after an reboot and it started normally after booting normally. Then I went away for ~8 hours (it was connected to power) and when coming back, it was completely dead.
It remained like that ever since. When I plug in the power cord, nothing happens, no single LED turns on and no sound is audible. Same when pressing the power button. Same without the battery. Same with the battery taken out and having held the power button for more than 30 seconds. Can the device even turn on without a battery connected? I tried with the charger from another Laptop (which has the same voltage and a fitting plug and provides enough current). Nothing happened as well.
Do you have some ideas what could have happened?
Edit 1: I did swap the single RAM stick into the second slot but nothing changed.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
How old your device is and is it running without any issue before this thing happened
さんによる
Ah sorry, I wasn't notified of your comment. It was running without any problems for 3+ years.
さんによる
コメントを追加
1 件の回答
ベストアンサー
Your device seems to not be POSTing, (not initializing the BIOS/UEFI) which most likely means you have bad hardware somewhere. Generally, a failed hard disk will not prevent the device from posting, it will boot normally and say “Boot device not found” or something of the sort. What you’re describing sounds like a case of a dead motherboard, as they tend to be intermittent when the fail, and then will fail full-stop without warning. As to fixing this, I don’t have any suggestions short of purchasing a new board and replacing the current one. Even so, it’s possible the issue is not the board, and is something else. Good luck, I hope that helped!
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
Well, I feared that ... :-( Thanks anyways!
さんによる
I was able to copy the data from the disk easily. But the laptop itself is still dead.
さんによる
@felixdivo That's great! I'm sorry the device wasn't reparable :(
さんによる
コメントを追加
回答を追加する
felix.divo さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 22
今までの合計 2,445
