メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Samsung Chromebook XE303C12-A01USは、11.6インチの画面と16 GBのSSDハードドライブを搭載したノートパソコンです。この小型ノートパソコンは、インターネットへのアクセスが容易で、さまざまなウェブアプリを実行できます。
Chrome os missing or damaged
Sir,
I have tried to download and created new usb with chrome recovery but as soon as it boots with usb the screen goes blank and stuck. I tried to got to recovery option then pressed ctrl+D then again it goes to “chrome os missing or damaged”.
The error code when simple pressing tab key “ 0X05 tpm read only”
After recovery buttons pressed it shows “ 0X02 recovery button pressed”
But in both the scenario screen goes to “chrome os missing or damaged”
Also opened whole laptop back removed battery replugged it but still the same.
Please help!!!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
1件のコメント
I hope you can get this question answered because Ive been asking the same exact one for a while now! let me know if you have ANY luck bro! thanks
さんによる
コメントを追加
2件の回答
最も参考になった回答
Install google chrome book recovery utility from google then launch the app and click on get started and follow on screen commands make sure you select the correct version of your operating system
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
I did. My chromebook shows " DAISY TEST A-A 9382 ". But i searched on google it says to download " SNOW " version so I did. But after I plug in the USB the screen goes Black and nothing happens. Please suggest.
さんによる
コメントを追加
When your Chromebook’s operating system (OS) isn’t working properly, you can recover it. Recovery is removing and reinstalling the OS.
Ref:
Recover your Chromebook
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
I did.. made recovery disk and as said before as well if boots the usb but screen stays on black screen (stuck) then I restart it by pressing power button again and again same message...
さんによる
0x05 tpm error in read-only firmware issue generally gets fixed by unplugging and reinserting the battery. But you have already done that. It seems to be a motherboard issue. Please get it checked by a certified technician.
さんによる
I also think so. Thanks for the help.. Lets check then...
さんによる
コメントを追加
回答を追加する
Rules Rhythm さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 23
今までの合計 4,657
