メインコンテンツにスキップ
2012年半ばモデル、A1278/2.5 GHz i5または2.9 GHz i7プロセッサー。
1624回答 すべてを表示
How can I transfer my current hard drive to a new MacBook Pro?
I have this Macbook Pro which has been working grand other than a terrible Logic Board issue. So I’m jumping ship and wanting to set up a new, refurbished mid-2012 Macbook Pro.
How can I transfer my hard drive over? The refurbished Macbook I’ve bought has a 128GB SSD, whereas the old one has a 500GB. I’ve tried just removing the hard drive and swapping the 500GB one in, but it gives me a hard drive read error. Do I need to wipe the old drive? Is there another procedure? Help!
Thanks—
Bernard
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
IF both systems have 2.5” SATA drives then technically you can swap them.
But! you’ll need to make sure you’ve updated the OS to the same version and you may have a second issue here!
The HD SATA cables are fragile! So you will likely need to also replace it as well. What happens is the rough surface of the uppercase aluminum wears the cable and you can also fatigue the bends if you over do it. This is more common with the 13” models but the 15” also has the same issue.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
try these steps really helpful
Open Migration Assistant.
Click Continue.
When asked how you want to transfer your information, select the option to transfer to another Mac.
Click Continue.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Bernard さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 72
